1987 e30 v8 not cranking over
xr666
Post Sun Sep 14, 2014 10:04 am
hi guys I have a 1987 325i auto shell with a 740i motor in place I have the fuel pump priming but it wont crank over
engine loom is 1992 auto, ecu is 404.
please help :cry:
jmc330i
Post Sun Sep 14, 2014 10:14 am
New conversion? Has it ever cranked?
Have you converted it to manual?
James
'91 325i Sport
'93 318i touring 16v
xr666
Post Sun Sep 14, 2014 1:28 pm
its a new conversion ,no its not cranked over and I converted it to manual I think its wiring fault :(
jmc330i
Post Sun Sep 14, 2014 1:58 pm
Auto inhibitor wiring?
From memory you can unplug the inhibitor loom which will leave two yellow/black wires loose above the gearbox - plug these two together.
James
'91 325i Sport
xr666
Post Sun Sep 14, 2014 2:28 pm
thanks for that I will give it a try now
GB69
Post Sun Sep 14, 2014 3:37 pm
Did the 740 have ews ecu? If so you need to cut the green wire going to pin 66 on ecu.
http://www.rtsauto.com/m60-swap-elimina ... 04-ecudme/
xr666
Post Sun Sep 14, 2014 4:05 pm
its a none ews loom as its 1992 loom pre ews or am I wrong in thinking that
GB69
Post Sun Sep 14, 2014 4:50 pm
xr666 wrote:its a none ews loom as its 1992 loom pre ews or am I wrong in thinking that
Dunno, but if pin 66 is a green wire, cut it and try start it.
xr666
Post Mon Sep 15, 2014 3:32 pm
on my loom pin 66 is black & yellow still no joy
Post Mon Sep 15, 2014 4:02 pm
Engine earth strap in place and OK?
xr666
Post Mon Sep 15, 2014 7:19 pm
earth is in place contact surface clean etc
xr666
Post Thu Sep 18, 2014 9:24 am
its now running :D
Post Thu Sep 18, 2014 10:04 am
xr666 wrote:its now running :D
Final comments like this can usually be interpreted as " I did/missed something extremely simple/silly, so I'm not giving the details".
Come on, spill the beans. What was it?
xr666
Post Fri Sep 19, 2014 11:58 am
I had ripped out the after market alarm system so had a few wires to by pass to get it going :o
Post Fri Sep 19, 2014 1:28 pm
Good to hear you got it going. Any pics/video clips of this car? winkeye
