A better drive
Mitchen
Post Thu Sep 11, 2014 11:24 pm
What are the top things to replace/restore if old and dead to improve the driveability (if that's a word) of an old E30.
Obviously up there would be the fuel injectors getting refurbed.
What else has everyone experienced that makes all the difference?
1990 320i Coupe SE
viewtopic.php?t=253048
BenHar
Post Thu Sep 11, 2014 11:25 pm
Shocks and suspension bushes.
Ben
Post Thu Sep 11, 2014 11:58 pm
Steering guibo.
BenHar
Post Fri Sep 12, 2014 12:01 am
Speedtouch wrote:Steering guibo.
Good call!
Ben
Johnaldridge101
Post Fri Sep 12, 2014 12:05 am
wheel bearings
suspension top mount bearings
gearbox oil
diff oil
brake fluid
Mitchen
Post Fri Sep 12, 2014 12:10 am
Johnaldridge101 wrote:wheel bearings
gearbox oil
diff oil
brake fluid
So you changing your diff oil made it a different drive?
1990 320i Coupe SE
Johnaldridge101
Post Fri Sep 12, 2014 12:23 am
sure did on my e30 325 cab.
there was no oil in it to begin with
Johnaldridge101
Post Fri Sep 12, 2014 12:38 am
Johnaldridge101 wrote:sure did on my e30 325 cab.
I HAVE noticed a difference after changing the oil in Subaru impreza rear diffs
also LDV mini busses
Motorhole
Post Fri Sep 12, 2014 9:11 am
Good call!
Ben
Just the steering in general. Throw the old bus-like rack in the bin and fit an E46 rack. That combined with a suspension overhaul will make the car drive like new, but with better steering.
Captain_Birdseye
Post Fri Sep 12, 2014 10:02 am
Motorhole wrote:
Good call!
Ben
steering upgrade doesn't feel original though, that's a downside for me.
SilverShadow
Hartge Crew
Post Fri Sep 12, 2014 10:23 am
Z3 short shift and refurbing the gear linkages.
Big bore throttle body
Post Fri Sep 12, 2014 10:38 am
New tyres may well make a decent difference, if the car's on knackered old Linglong ditchfinders...
ross_jsy
Post Fri Sep 12, 2014 12:33 pm
Captain_Birdseye wrote:
Motorhole wrote:
BenHar wrote: Good call!
Ben
Have you ever driven a car with a faster rack?
jon-m42
Post Fri Sep 12, 2014 12:56 pm
A Regular Service:
*Spark Plugs
*Fuel Filter
*Engine oil
*Oil Filter
*Air Filter
You can also check and change if necessary:
*Wishbones/bushes
*suspension springs and shocks including top mounts
*Track rod ends
*Power steering fluid
*Break fluid
*disks and pads
*All new tyres filled to correct limit 32psi for 205/50 R15
Doing all this should help and hopefully restore OEM driving quality and pleasure or as close to.
What are your plans for this car ?
Gert_8
Post Fri Sep 12, 2014 1:32 pm
a new car?
HairyScreech
Post Fri Sep 12, 2014 1:33 pm
I have to say the only thing you notice with a quicker rack than the e30 one is your much less scared when the back steps out and you spend less time doing bus driver impressions.
Other than that the car is exactly the same day to day.
