Post
Sun May 31, 2015 6:44 pm
It's a hybrid of sorts. Turbine housing is a normal KKK one with the flange to fit straight to a 944/Audi Quattro manifold, which means its not the usual T3 or T4 flange on aftermarket M20 manifolds.
Chances are it will work perfectly well on a M20, as the engine it was intended for is also a 2.5ltr 12V, and while it's impossible to say exactly what it is from those pics, size wise it's not a huge compressor, and by looks of it its still got the small 944 turbine housing, so will spool fine.
But you'll need a custom manifold as the flange is the usual Porsche/KKK one.
