Car is lower on one side
Jona1971
Sun Sep 07, 2014 12:16 pm
Hi,
The gap between the top of my tyres and the wheel arches is 80mm all round except the rear offside which is 50mm.
I've had a look underneath and the spring looks OK. The rebound test seems fine with 1 bounce.
Any ideas?
(It's a 318i auto pre-facelift saloon)
Thanks, :?
Sun Sep 07, 2014 12:44 pm
Assuming you've done the measurements with the car parked on level ground, the possibilities are;
1. Bent trailing arm
2. Seized trailing arm bush(es)
3. Different tyre profile/wheel size
4. Facelift rear wheelarch has been fitted - those were about an inch lower at the back than the pre-facelift ones.
5. Sagged coil spring
6. Broken coil spring mounting platform
Jona1971
Sun Sep 07, 2014 1:22 pm
Thanks for that,
I turned the car around 180 degrees and the measurements are the same.
1. ok, don't know - could be
2. ok, don't know - could be
3. same wheels and same make and profile of tyres
4. I measured both sides of the car and the gap between the wheel arch and the top of the car is the same
5. I measured the spring and the "saggy" side is 5 inches and the ok side is 6 inches
6. Can't tell, but it looks ok
It's getting the car MOT'd next week I'll get them to have a good look.
My rear disc brake conversion may be closer than I thought...
Sun Sep 07, 2014 1:33 pm
Sounds like a sagged coil spring to me...
Jona1971
Sun Sep 07, 2014 4:23 pm
Thanks, I think so too.
TheDutch
Sun Sep 07, 2014 4:55 pm
Could also be the damper, replacing mine made a noticeable difference to ride height.
Jona1971
Sun Sep 21, 2014 3:02 pm
Right, I replaced the trailing arms, trailing arm bushes and springs when doing a rear disc conversion. The car handles better with less wallowing around the corners but the rear offside is still 30mm lower than the rear nearside.
I have the dampers from the Touring donor car but have not fitted them due to no access to the top as I've got a big lpg tank in the boot.
Also, I noticed the rear beam moved when jacking up the car, could it be these bushes?
Any other ideas?
Thanks, :?
Sun Sep 21, 2014 9:40 pm
Jona1971
Sun Sep 21, 2014 10:26 pm
Thanks Speedtouch,
Yep, reading the article it looks like that's the problem.
Jona1971
Mon Sep 22, 2014 11:23 pm
OK, I've ordered the bushes.
How long should this job take? I'm considering letting the garage do it when they MOT the car this week.
Jona1971
Fri Sep 26, 2014 4:44 pm
Rear bushes replaced and its all OK now. No nasty thunks or dodgy ride height.
Fri Sep 26, 2014 4:48 pm
Good to hear that, dude. 8)
