325i piston ring
markus_74
Post Sat Aug 30, 2014 11:15 am
hello,
finally got 325i piston complete with ring.
my question can I use the used piston ring that come with the piston? or should buy new one?
and what type of piston that I have? low or high comp?
regards
markus
**BANNED**
Post Sat Aug 30, 2014 11:51 am
Fit new rings! :D
Youth is wasted on the young.
gromgsxr
Post Sat Aug 30, 2014 1:26 pm
low comp mahle by the looks of it
markus_74
Post Sat Aug 30, 2014 5:21 pm
thank you for all the info.
markus_74
Post Sat Aug 30, 2014 5:50 pm
just want to make sure,
does m40 318i piston ring is same with m20 325i piston ring?
both piston have 83.98mm
m20 325i
06 REPAIR KIT PISTON RINGS 83,980MM(0) ? 11251713192
m40 318i
04 REPAIR KIT PISTON RINGS 83,980MM(0) 4 11251713192
Post Sat Aug 30, 2014 5:58 pm
I would guess so, seeing as the last 7 digits of the part number are the same.
Why not put it into RealOEM and find out?
markus_74
Post Sat Aug 30, 2014 6:13 pm
yes, I have try realoem and I found ,
bearing shell is same with m40 and m50 also
the big bearing shell is same with m50 325/525 but for this I[m not sure as it has a lot of different combination of bearing shell
