locating heater fan: with pics NEED MORE HELP!
stevo
Fri Jan 06, 2006 3:45 pm
in conjuction with this thread
http://www.e30zone.co.uk/modules.php?na ... ic&t=24823
i need help finding the fan, and/or the resistor board. i started taking things apart earlier but got stuck...
emm, could someone point out to me where these bits are :?
thanks in advance
E30Mark
Fri Jan 06, 2006 3:58 pm
The fan is inside, under the dash... don't know where the resistor pack is, but i would guess it's attached to the heater assembly under the dash somewhere...
PM for details
stevo
Fri Jan 06, 2006 4:30 pm
oh right, i always thought it was accesed from the engine bay :roll:
any other info on getting to it?
cheers mark :thumb:
E30Mark
Fri Jan 06, 2006 4:38 pm
Looks like i made a mistake, just taken a look at my Bentley manual, and it says you access the heater blower from the engine bay! well i never knew that..... You need to remove the panel in your last picture, it's behind that.
I'm just reading the rest of the article to find out where the resistor pack is....
I'll be back..
PM for details
E30Mark
Fri Jan 06, 2006 4:46 pm
You were right..
The Blower motor resistors are behind the blower motor.
So there fore you will need to remove the panel that is behind the the wiring on the bulkhead as in your picture 2. Then remove the motor which will gain you access to the resistors.
Sorry for the earlier confusion :oops:
PM for details
Fri Jan 06, 2006 4:47 pm
E30Mark
Fri Jan 06, 2006 4:50 pm
E30BeemerLad wrote:follow this link chaps
http://www.bmwe30.net/cgi-bin/datacgi/d ... Section=10
no charge :P
oooh who's a clever chappie! I'll throw my manual in the bin now, and get on with my tax return :roll:
PM for details
stevo
Fri Jan 06, 2006 5:21 pm
no charge :P
excellent, i thought it was just metal behind the rubber mat thingy,
thanks guys 8)
Fri Jan 06, 2006 8:20 pm
Link is good for showing you how to get to the motor, but don't be surprised if you can't find the resistors.
Everttime I've had occassion to hunt for the resistor pack, I've found it slotted into the left side of the heater casing, near the electric water valve.
Fri Jan 06, 2006 8:27 pm
E30Mark wrote: I'll throw my manual in the bin now, and get on with my tax return :roll:
If only there was a manual for tax returns :(
E30Mark
Fri Jan 06, 2006 8:56 pm
DanThe wrote:If only there was a manual for tax returns :(
Perhaps we could ask Haynes to write one 8O
PM for details
MONSPORT42
Sat Jan 07, 2006 9:44 am
Think BMW fitted two types of blower motor. One with resistors located as Brian has described and one , like mine slotted into the front between the 2 rotors. There's a 'belt' fixing wrapped over the centre. Under it and you can lift up the top cowling and expose the fans and the resistor pack slotted in the front. A good clean up and lubrication cured all my heater blower probs - noise and speeds.
Just read link - look before you leap - and it describes it better than I've just done. But it's not a hard job. Just a bit messy!
YOUR LEFT FOOT'S FOR BRAKING
stevo
Sat Jan 07, 2006 11:54 am
with many thanks to emotechnik pm'ing me i think i'm on the right track in looking for the resistor pack, i still cant find it though :cry: . it's part number 5 here http://www.realoem.com/bmw/showparts.do ... g=64&fg=35
i stripped the glovebox and stuff but i cant see what i'm looking for
please help guy's, i'm pulling my hair out here!
stevo
Sat Jan 07, 2006 3:33 pm
anyone? :(
i'll need to put the dashboard back together soon to use the car in the morning but any help is mucho apreciated at any time
thanks for all the info so far 8)
mrLEE30
Sat Jan 07, 2006 3:47 pm
E30Mark
if haines wrote it then it would be crap!!!
winkeye
mrlee
kombikat
Sat Jan 07, 2006 5:08 pm
Thank God I am not the only person who can't find the famous resistor pack.
The passenger side heater on my facelift 320i looks like the pics posted on this thread.
Please, can anyone put an X where the resistor pack is?
Gordon
Sat Jan 07, 2006 8:37 pm
Should be able to find the resistor pack by following the wires.
Emotechnik
Sun Jan 08, 2006 1:20 am
stevo wrote:with many thanks to emotechnik pm'ing me i think i'm on the right track in looking for the resistor pack, i still cant find it though :cry: . it's part number 5 here http://www.realoem.com/bmw/showparts.do ... g=64&fg=35
Top left of your first picture is an electrical connector (green and possibly yellow wires) connected onto a browny/pink coloured square unit, this is your target!
Squeeze the 'lugs'on the connector and disconnect the plug, then, squeeze the 'lugs' on the resistor pack and remove it from the heater box, and then test it's resistance and check continuity from the fan switch to the resistor.
stevo
Sun Jan 08, 2006 11:55 am
I'VE GOT IT!!!!!!
(can anyone guess i got a digital camera for christmas!?)
the resistors themselves are ok but the bits they're attatched to are rusty as hell. once the skin grows back over my fingertips i'll try'n take it apart and clean it up and post the results
a big thanks to everyone who helped :clap:
oh i also found two cassettes from a previous owner and two football sweeps dated 12th mar '94!! how they got under the dash i'll never know :o
