51mm front strut and ABS set up....
stew72
Post Sun Aug 10, 2014 8:34 am
What's a complete 51mm strut and ABS set up worth? Complete front and rear corners (hubs, calipers the lot), Pump, ecu and associated wiring?
Or would it be better to split it down?
Thanks.
Post Sun Aug 10, 2014 11:57 am
ABS on an E30 isn't exactly rare, but it is extremely reliable. Conversions of non ABS cars to ABS don't seem to happen that often either, so all in all, the value of the bits you have is in the suspension and brakes, rather than the ABS.
In short, worth little more than their non ABS equivalents.
