Guys,
S50 conversion...
As above... Which gearbox mounts and gearbox support do I need to use? I'm using the S50b30 engine and 5 speed box in what was an auto shell.
Also which gear linkage do I need to use
Thanks in advance boys and girls!!
Which gearbox support/mounts do I need?
crossie
s50 linkage - e30 back mount
e30 gearbox mount
e30 gearbox mount
Z2TT
Is there any difference in using E30 or E36 M3 linkage?
Arent they the same length?
Because from what i see the UUC DSSR suits E36 and E30, which would mean then E30 and E36 links should be interchangeable?
