Lollipop bush pressed in off line..
G-Bear
Post Wed Jul 16, 2014 3:34 pm
Just got back from the garage up the road where I had new bushes pressed in. Noticed on one, the arrow is slightly off the mark. Is going to cause issues or is there a bit of leverage?
maxfield
Post Wed Jul 16, 2014 3:47 pm
Not something is worry about. It's only a couple of mm.
G-Bear
Post Wed Jul 16, 2014 3:50 pm
Thanks maxfield, you're being a great help today :thumb:
Post Wed Jul 16, 2014 7:12 pm
It will change the suspension geometry marginally on that side. There is a 50% chance that it will bring the geometry closer to what it should be, and a 50% chance it will make it marginally worse.
G-Bear
Post Thu Jul 17, 2014 7:31 am
Brianmoooore wrote:It will change the suspension geometry marginally on that side. There is a 50% chance that it will bring the geometry closer to what it should be, and a 50% chance it will make it marginally worse.
Either way I'm sure it will be an improvement from how it was before.
HairyScreech
Post Thu Jul 17, 2014 1:07 pm
Really fractional change.
When doing the sus setup on the race cars we found that it was about 5% change before the driver noticed anything and even then we are talking tiny change.
Now a road car with lots of rubber elsewhere.....
