Right, there is no ICV on my M10 it has an "Auxiliary Air Slide". It helps idle when the engine oil is cold and more viscous. When cold its open and lets more air in and when hot it closes up.
The permanent 12v supply is for heating effect generated from the small coil inside. Its mounted directly to the engine so it heats up quickly.
There is a 7mm adjustment nut on the unit which can help with idle:
1. undo the nut a bit.
2. the thread the nut is on is in an oblong groove and can be moved inwards toward the centre (to lower r.p.m. at idle) or outwards toward the rim (to increase idle).
3. Move nut into position you want listening to the idle and tighten.
4. Idle r.p.m. was 500 now about 650. (not perfect but hopefully no more stalling at the lights).
Hope this helps people with an M10 Chromie. Mr Haynes tells lies...
