i would appreciate any help or advice on this as i am hoping to start this project asap
thanks
james
looks like i have everything i need to go ahead, thanks very much for your helpJhonno wrote:you need engine/box/prop/diff and ideally rear discs
quite an 'easy' swap, need to put the seperate header tank etc in tho as the 1.6 uses one on the side of the rad
Why?? Surely my suspension should take the 2.5nav786 wrote:i will be doing the same on my cab very soon. you will need to upgrade you front brakes to the 6 pot setup, and also the suspension for the added weight.
