does m40 and m20 prophaft different length?
markus_74
Post Sat Jul 05, 2014 2:37 pm
hello,
Can I use my m40 propshaft to m20 engine with getrag 240 or getrag 260 and medium size diff?
or I should buy m20 propshaft? that may be shorter or longer?
thank you
Markus
**BANNED**
Post Sat Jul 05, 2014 5:14 pm
Difference in the propshaft's is in the front section.
240 'box is shorter than 260,so the 260 prop front section is the shortest of all.
M40 engine sits further forward than M20,so it's prop front section is longer than either of the 6 cylinder one's.
Both half's of the propshaft should have a white alignment dot,if this is missing then align the two parts with the yokes in the same plane,this limits the available positions to just two!
Youth is wasted on the young.
markus_74
Post Sat Jul 05, 2014 7:16 pm
can I cut the front section and then weld again without losing it is balance? or should buy proper propshaft for m20?
**BANNED**
Post Sat Jul 05, 2014 8:05 pm
markus_74 wrote:can I cut the front section and then weld again without losing it is balance? or should buy proper propshaft for m20?
I would guess that depends on how good a welder you are.
Post Sat Jul 05, 2014 8:15 pm
It will almost certainly loose balance if you cut and weld, but there's a DIY trial and error method of balancing propshafts:
Put two jubilee clips around it, and experiment with their position. With the two worm assemblies opposite each other they will have no effect, and with them both on the same side, they will have maximum effect, and everything in between.
