Sunroof issue
M3Jim
Post Sat Jul 05, 2014 9:38 am
My sunroof keeps going out of sync. As in the positions it stops in. I keep resetting it and its getting annoying now but I can't see why it keeps doing it. Any ideas what needs doing to it or what I need to replace. Ta
Post Sat Jul 05, 2014 10:38 am
Motor assembly. Cog must be jumping in the gearbox.
M3Jim
Post Sat Jul 05, 2014 10:48 am
Doesn't make any sounds like the cogs jumping though, and doesn't go out of sync straight away. Will get a motor assembly, thanks Brian
Post Sat Jul 05, 2014 10:57 am
M3Jim wrote:Doesn't make any sounds like the cogs jumping though
That's why I think it's internal in the gearbox, rather than the drive to the cables jumping. If these jump, then you will hear it, and the roof is likely to go out of sync side to side.
There's a camshaft attached to one of the intermediate gears on the gearbox which works a microswitch that in turn controls the motor, and the slippage must be between this and the actual drive cog.
