M20b25 swap into M40 - do i need to check the 101 connector?
nathan-neon
Post Sat Jun 28, 2014 7:06 pm
Hi all,
Ive just finished putting an M20b25 into my 318i cabrio, I took my time and took it all from a donor car so I had everything I needed. It doesn't start.
There is power to the dash, there are many new parts but it doesnt even try to start. I had help from the e30zone wiki guide but can anyone suggest what to check? Is the fault with the 101 connector?
Thanks in advance, Nathan.
Post Sat Jun 28, 2014 7:27 pm
Does it even turn over on the starter? Check the engine-to-body earth strap as a first port of call.
http://www.e30zone.net/e30zonewiki/inde ... oubleshoot
nathan-neon
Post Sat Jun 28, 2014 7:43 pm
The car is definitely earthed, its been checked. It wont turn over off the starter, no. :(
TPS
Post Sat Jun 28, 2014 8:25 pm
Have you bridged Pin 30 & 87 to see if the Fuel Pump is working?
Post Sat Jun 28, 2014 10:22 pm
http://www.e30zone.net/e30zonewiki/index.php/Starter
Try bridging the appropriate pins in the diagnostic socket to get the starter to operate...
