I need a bit of help.
It idles fine, and accelerates well above 3000rpm, but until then is hesitant and lumpy. However, not so bad if I put my foot down.
Any ideas? Thanks in advance
(Oh, its a 1987 M10B18 Auto)
Any air leaks, rubber boots, vacuum pipes?Jona1971 wrote:Hi,
I've got a new AFM, so still puzzled...
Have a look here for common air leak sources > http://www.e30zone.net/e30zonewiki/inde ... #Air_LeaksJona1971 wrote:Just checked rubber boot and its fine.
I'll have another check for air leaks elsewhere, should I be squirting carb cleaner or WD40 at the joints? (when engine cold I think?)
Thanks,
That would be my starter for 10, a zoner overhauls injectorsJona1971 wrote:New fuel filter last month as part of major service.
Never had the injectors serviced.
Not exactly a zoner as such, but one of our traders. Look in the traders' forum!aimlessrock wrote: a zoner overhauls injectors
and did a smashing job of mine.. Think he charged about £10 per injector... his name escapes me for the minute.
So it should! LPG is a much more suitable fuel for spark ignition engines than petrol.Jona1971 wrote:Thanks chaps.
Another puzzler, I've just filled it up with LPG and it runs better on gas than petrol...
Injectors!Jona1971 wrote: A bit chuggy and hesitant still at half throttle. Chuggs when cruising at about 2,200 rpm. Drives better on lpg than petrol, more responsive.
