jimbom30cab
- Tech 1 freak
Post
Sat Jun 21, 2014 1:08 pm
There is a lot of options here:
http://www.catcams.co.uk/acatalog/BMW_E ... ngine.html
I want something which idles ok and gives some extra push up the rev range.
It's for everyday weekend type fun driving, not the track
which would anyone recommend ?
Should i also then get a re-map, i've got a Danthe ECU at present?
Thanks M52 gods
BMW_E30vert
Post
Sat Jun 21, 2014 8:33 pm
How much do a pair of these cams cost? ive got a m54b30 inlet and s50us exhaust cam but have just picked up a pair of second hand shricks so the others will be up for sale soon, cant help with a recommendation but here are some standard bmw cam specs:
M52 inlet- 228*@9mm lift
M52 Exhaust-228*@9mm lift
S50/52US inlet-252*@10.2mm lift
S50/52US Exhaust-240*@9.7mm lift
jimbom30cab
- Tech 1 freak
Post
Sat Jun 21, 2014 9:59 pm
Thanks,
"m54b30 inlet and s50us exhaust cam"
that's a odd combo, i know nothing about these engines, is that a well known combo of cams?
thanks
BMW_E30vert
Post
Mon Jun 23, 2014 8:13 pm
It is an odd combo, not quite the m3 US cams but better than stock m52
This would be the spec with the said cams-
Intake- 240*@9.7 lift
Exhaust- 240*@9.7lift
jimbom30cab
- Tech 1 freak
Post
Mon Jun 23, 2014 11:41 pm
thanks man, worth thinking about that
anyone else cam'd up an m52 ?
Post
Tue Jun 24, 2014 9:58 am
Don't bother Jim. I am guessing two cams will cost the thick end of a bag. You may gain 10 bhp @7000 along with a crap idle.
jimbom30cab
- Tech 1 freak
Post
Tue Jun 24, 2014 10:57 am
Thank Pete, am thinking that way also
I'll go on a diet to reduce some weight, be cheaper
Cook318IS
Post
Tue Jun 24, 2014 11:25 am
I went for american m3 S52 cams, managed to pick them up for about £300 - £350 if i remember correctly. The cost of cat cams or shrick put me off a little bit. I'd recommend a live map if you do get cams, I'll do mine if my exhaust ever stops blowing. If you do decide on cat cams i'm pretty sure rally prep are a dealer for cat cams (
http://www.e30zone.net/modules.php?name ... le&u=25649 might be easier to phone them though)
Post
Tue Jun 24, 2014 12:56 pm
You would be much better off putting that grand towards a proper 3.0 build, which is a different animal altogether
jimbom30cab
- Tech 1 freak
Post
Tue Jun 24, 2014 1:04 pm
Now you got me thinking there Dan, I remember you did that build recently, it was proper nice. Thanks. Do you remember the thread to wet my appetite
by the way, I'm going to get a team of crack test drivers together off the zone to do a e30 engine mod road test......basically me Phil and Rob. The line up is
2.7 m20
2.8 m52
3.5 m30
all have some off the shelf mods
top gear style write up with videos
jimbom30cab
- Tech 1 freak
Post
Tue Jun 24, 2014 1:19 pm
Ok,daft question I know but can the m52 be live mapped, as I know the DME 1.3 can't which is an iterative read/write process
