kick down on switch-able auto
j4gz
ok i took the motor out for a good run along the m4 and noticed while driving that when i took my foot of the accelerator at around 80 the kick down automatically started revin up and changing gear down about twice what is this issue i also have a mild chip from here could that be part of the cause as i don't think it is normal it wernt in sports either ?
j4gz
any advice for me guys on this thread ?
j4gz
yeah always in D and what is the SEM switch ? is that the switch-able selector ?diable wrote:Is in D and is the SEM switch ok as if its "loose" it can switch unnecessarily.
mark_i
I had the same problem with an EH auto...
replaced the soggy gearbox mounts and correctly adjusted the shifting linkage and all sorted
