E46 m3 manual on 4 post rear wheels spinning
seanboy
Post Thu Jun 12, 2014 12:40 pm
Is this right,
One in yard going cheap!
It was on 4 post ramp in neutral running and rear wheels spinning but you could stop by putting pressure on one wheel with your foot.
Few little issues but are these a money pit?[/list]
Post Thu Jun 12, 2014 12:47 pm
Sounds like a typical diff operating as they do, but there must be a lot of gearbox drag for it to be turning the diff if it's in neutral; cold gearbox oil maybe?
Check the rear subframe mounts/floorpan, as they are reknowned for cracking.
Idol
Post Thu Jun 12, 2014 12:55 pm
Defo check the subframe mounts as they defo crack as Speedtouch says. I had a e46 m3 vert but had no probs with it, but it was a 53 plate with low miles. Sold it last year with 50k on it.
Idol
Post Thu Jun 12, 2014 12:58 pm
Also check where the pipes join the back box. The couplings crack and it's a new centre section or fabrication job
Post Thu Jun 12, 2014 1:31 pm
Torsen LSD?
harry_p
Post Sun Jun 15, 2014 10:55 am
Very normal for wheels to spin in neutral if jacked up, it's just the thickness of the oil transferring movement from the input shaft.
cheers,
harry
