Annoying 1st gear
SilverShadow
Hartge Crew
Post Fri Jun 06, 2014 12:03 am
I sourced a 240 gearbox from a trusted zoner however been experiencing some issues with first gear.
when I fitted the box all the seals where changed and the selector linkage parts replaced, I also fitted the z3 1.9 short shift.
The issue I'm experiencing is that when I try putting it in 1st there's a little bit of a struggle, I need to depress the clutch a couple of times and then goes in fine?
All other gears are spot on.
Any ideas what could be causing this? low gearbox oil?
milescook
Post Fri Jun 06, 2014 7:25 am
Maybe clutch fluid running low, or needing some bleeding?
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
SilverShadow
Hartge Crew
Post Sat Jun 07, 2014 11:33 pm
Still havnt had a chance to look at this but 2nd gear has started to do the same.
After with some persuasion the gears will go in but not ideal when you pulling off in traffic behind you.. :(
Post Sat Jun 07, 2014 11:39 pm
As above, try bleeding the clutch, and yes, check the gearbox oil level; are you sure it has the correct grade oil in it?
SilverShadow
Hartge Crew
Post Sat Jun 07, 2014 11:56 pm
Speedtouch wrote:As above, try bleeding the clutch, and yes, check the gearbox oil level; are you sure it has the correct grade oil in it?
What grade of oil do you recommend that won't encourage that layshaft rattle?
Planning to get this on stands tmrw and look at clutch fluid and change gbox oil.
Post Sun Jun 08, 2014 12:13 am
Laith
Post Sun Jun 08, 2014 3:04 pm
How does the clutch pedal feel?
