M20 2.5 max power standard clutch
mt500ish
Does anybody know how much power upgrades can a standard clutch take?
jimmyspeed
if you use a uprated pressure plate made by sachs they can hold a fair amount its the route I'm going for with my turbo build
think the part number is 883082999618 - take a look on here they were a uk distributor i found - http://www.racepads.co.uk
have a look at these there some pages i bookmarked whilst researching
http://www.e30zone.net/modules.php?name ... ted+clutch
http://www.e30zone.net/modules.php?name ... c&t=219194
reggid
how much power do you want it to take?
E30 325is with M20B31
I found the limits with my M52 3.0 build, approx 240hp and Lbft, but this was only after a mornings abuse around Oulton Park, started to slip when hot in the afternoon at high revs.
I now use a standard Sachs cover and a 5 paddle sprung centre plate without problems
mt500ish
Thanks for your answers gentlemen.
It is a m20 engine with lighned flywheel revs well but think it might have clutch issues put standard clutch in it but when first started it was not convinced the clutch will take it,
What lbft did you get from m52 stroker if you do not mind?
When tested just after building with standard 2.8 ECU, cams and a crappy M20 exhaust it pulled 239Lbft
