Best way to clean lead to window motor?
Mike645
Post Thu May 29, 2014 9:35 am
Hi there,
I noticed that the power leads to my window motor were dirty causing many problems with the windows.
What is the best way to clean them?
They have like a white mineral crust inside the leads. Have attached photo link below.
https://www.sugarsync.com/pf/D7021033_784_216878788
Any suggestions much appreciated.
Mike645
Post Thu May 29, 2014 11:17 am
acutally I was able to figure it out by googling more... seems like electrical contact cleaner and small wire brushes the way to go.
Post Thu May 29, 2014 12:06 pm
Indeed, that will do the job. You could use a fine jeweller's flat-bladed screwdriver to gently scrub at the inside of the terminals to remove the worst of the tarnish.
Use WD40 or vaseline afterwards to protect from further corrosion.
