Rough idle, misfire, wants to die
Hi i have a g 1989 325i cabby preface which was running fine for a while after a small service, new maf, new idle control valve, new intake boots which then finally brought the idle down correctly. Yesterday i thought i had perfected the engine side of things, fired her up today and she started to rough idle, misfire and shook the whole cabin quite roughly. it spluttered between 100-800 rpm. Any ideas what to look at first? thanks
Try disconnecting the ECU or battery and leaving it for an hour or so to reset the ECU. Then let it idle for at least 10 minutes, switch off, then go for a drive throughout the rev range.
This ensures base idle settings are learnt and full data transfer from the EPROM chip.
