Post
Mon Feb 14, 2005 3:42 pm
My smoked hellas started condensating inside not long after I had them, what I did was to take the backs off them, then applied heat to the outside of the lens until the condensation cleared, when re-fitting the backs I made sure they were done up tight, applied a little grease, and on the headlamps made sure the three LHD/RHD adjusting screws were done up tight. Since doing this I haven't had any major problems except for a slight bit of misting in really bad weather in the bottom of the right headlamp which soon cleared.
As for the alignment, take it along to your local MOT place and ask them to set them up.
