how to check transmission is still good or not?
markus_74
Post Sat May 10, 2014 5:53 am
hello,
I'm in the process of buying m20 transmission, and I take my mechanic with me to check it.
and after he grab the front center rod of the transmission he try to rotate it turn right and left, after a few second he feel that it has a play a bit.
does it is sign that the transmission is not good? or it is normally?
any other method to check?
note: car is not run without engine so it is only transmission only.
