pair of e46 cab rear top mounts: 33526779670
set of e30 rear trailing arm bushes: 33329061945
pair of E30 M3 eccentric lollipop bushes: 31129061222
3.0 / Z3M Differential mounting bush: 33172228425
bracket: 13541711061
Rubber boot: 13541722847
Rubber boot: 13711707767
Gasket : 33111210405
Gear selector rod joint: 25117501309
Dowel pin: 23411466134
2 x O ring: 25111221243
Spacer ring: 25111220199
Circlip: 07119932863
Gear lever: 25117527252
2 x Spacer ring: 24111220439
2 x Circlip: 25117571899
Shift lever bearing: 25111220600
PRICES PLEASE
Cotswoldbmw
Hi There
pair of e46 cab rear top mounts: 33526779670 £54.91 the pair
set of e30 rear trailing arm bushes: 33329061945 £22.14 for one side
pair of E30 M3 eccentric lollipop bushes: 31129061222 £40.45
3.0 / Z3M Differential mounting bush: 33172228425 £122.41
bracket: 13541711061 £2.35
Rubber boot: 13541722847 £19.85
Rubber boot: 13711707767 £19.85
Gasket : 33111210405 £2.48
Gear selector rod joint: 25117501309 £30.78
Dowel pin: 23411466134 £1.04
2 x O ring: 25111221243 £3.34 for 2
Spacer ring: 25111220199 £1.50
Circlip: 07119932863 £0.30
Gear lever: 25117527252 £50.41
2 x Spacer ring: 24111220439 £1.00 for 2
2 x Circlip: 25117571899 £1.62 for 2
Shift lever bearing: 25111220600 £7.34
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 17679
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett”‹
Brett”‹
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
