m10 engine wiring / carb options
tickle
Post Mon Jan 02, 2006 3:03 pm
i have a 1.8i m10 engine in a m40 1.6i car, im not sure on what injection system it is, but has 4 injectors and the "spider" type inlet system. after spending the night looking through the pages in these forums i am keen to get the m10 fired up and plummed in with a 2.2/2.0 conversion from the early m10 (pistons/rods) + s14? head, although this is down the line.
For the time being i want the standard 1.8 m10 in, running on carb.
Can anyone advise me on exacly what is needed to run this injection engine on a carb (Wiring loom choices e.t.c) and a carb setup that wont eat all my fuel but will cope with future mods? cheers! :D
Post Mon Jan 02, 2006 4:02 pm
The M10 injetion system should be running on the L-Jetronic system.
You mentioned in your other thread that the engine is in but the wiring isnt?
Does this engine have a loom on it?
If you want to fit a standard carb you still need the correct loom/ECU
I would get the injection up and running, it will be easier and more beneficial, in the mean time you can build your 2.0 L engine out of the car
tickle
Post Mon Jan 02, 2006 4:12 pm
it has an m40 engine loom in it, can i run it off this wiring, id rather swap a loom than put an m40 back in there, why injection over webers? even if i have to buy another m10 to rebuild to a higher spec. :x
Post Mon Jan 02, 2006 4:18 pm
It will be a lot less hassle to put the correct loom in than trying to adapt that later M40 one.
I meant the standard carb or replacement manual choke weber one that is often the case, these are total shite and hardly go above 20mpg.
As for bigger carbs i havnt got a clue mate.
HTH
tickle
Post Mon Jan 02, 2006 4:26 pm
where would i be able to source a wiring loom from to suite the car? i take it that i could get a loom that will fit all my hardware that came with the m40 car, and fit a m10 e.c.u and engine, if so could you suggest a loom to use :D
Post Mon Jan 02, 2006 4:30 pm
An M10 one :D
The engine loom is meant to stay with the appropriate engine on removal/reffiting. Just plugs into the big connector on the bulkhead and the ECU plug feeds through the drivers side of the bulkhead under the dash.
tickle
Post Mon Jan 02, 2006 4:36 pm
excellent, youve bin a big help. im used to working on crappy mainstream fords whith all of the hastle that comes with them. do i need a 1.8 m10 loom or will a 1.6 m10 do the same job with a 1.8 ecu.
Post Mon Jan 02, 2006 4:43 pm
You need the M10 1800i loom/ECU :thumb:
I put one in a 316 a few months ago if you need anymore help
tickle
Post Mon Jan 02, 2006 4:49 pm
ill take you up on that offer for anymore advice as no doubt i will have some kind of a problem at some point, thnks for the help!
