Got a seepage from the oil filter, underneath can feel a circular indentation where oil is dripping out,
had a little look on realoem,,
is it part no 7 in this link, if someone could confirm?
thanks
Leak from oil filter housing - correct part?
Would have helped if you'd actually added the link, but assuming it's a M20B25 engine you're talking about, then kit 7, part# 11 42 9 059 338 is what you need. Fit all the parts - they are slightly different from the originals, and watch for the thermostat element falling out when the cap is off.
bmw9818
lol true but yeah -
http://realoem.com/bmw/showparts.do?mod ... g=11&fg=30
thats the one i was checking, nice one!
also thermostat cap? engine will be on the bench when i sort it... but where exactly/what is that?
The bits you are buying are the 'thermostat cap'! That's why the filter housing has the hole in it that the cap blanks off.
