Heater Blower Motor
Hopchop
Wed Apr 23, 2014 10:39 am
Does anyone know is it possible to get at the heater blower motor with an M52B28 engine fitted as it sits right up against the bulkhead?
JamOnIt
Mon Jun 15, 2015 9:05 pm
Did you get anywhere with this problem as I need to change my heater resistor?
Tue Jun 23, 2015 6:11 pm
WillNZ wrote:Should not be a problem to remove the cover hiding the blower motor and getting it out to service it. You will probably have to remove the plastic manifold cover to make life easier.
IIRC, the lower left screw is difficult to get at, and is best replaced by a steel tab that hooks over the bulkhead to hold that corner in, and just refitting the other three screws.
