Built e30 m20 b25 from e34 m20 b20 engine block
markus_74
Post Sat Apr 12, 2014 9:26 am
Hello, Zoner
I have difficult to find any e30 m20 b25 high compression here, so I think I will built it from e34 m20 b20 engine block (1989).
Does is it possible? and what difficulty?
I have read wiki zone that it will difficult because :
1.oil check dipstick will be different location
2.engine block not match with b25 cylinder head this is wiki said
"The heads themselves are not interchangeable; fitting a 731 head to a 325i will result in the valves hitting the pistons, while fitting an 885 head to a 320i will result in the valves hitting the bore lip. 885 heads are therefore completely incompatible with B20 or B23 blocks"
so what head should I use and what the sign and from what year?
Thank you need all advice from zoner.
Thank you
