Fluid inside trailing arms
Jatin
Sun Apr 06, 2014 9:14 pm
I've been repairing the rear trailing arms.
Has anyone noticed a small plastic bung on the side near the hub/bearing area.
Out from the hole flowed an oily liquid which smelt flammable.
Does anyone know what it is.
sag
Sun Apr 06, 2014 9:37 pm
I had the same thing when doing my arms. I think it's some type if waxy oil. To prevent the arms rusting inside out as they are hollow
Jatin
Sun Apr 06, 2014 10:24 pm
Ok thanks - what would I use to replace it
bigbird76
Sun Apr 06, 2014 11:01 pm
I remember this stuff when I refurbished my arms, I suppose a drop of thick oil would not do any harm and it is a cheap method as long as your plug is good.
Cavity wax is another option but that would dry off inside.
Mon Apr 07, 2014 9:23 am
Just pour waxoil back in, if its sealed up with the bung it wont dry out, adding some engine oil will help too
