Broken heated washers loom plug
BHadley
Post Sat Mar 29, 2014 6:29 pm
Hi all
I have a broken wire right next to the connection plug for the heated washer jet loom to plug into the main washer pump ( it piggybacks into it).
It's a facelift 318is 1991
Are my options;
1; interchangeable with e36 type? as I can get access to that type of car to get a plug and join to loom.
2;would bmw be selling these connectors new?
3; is it worth soldering the wires direct into the main washer loom?
Any other ideas welcome
Post Sat Mar 29, 2014 8:51 pm
All three of your options are viable.
BHadley
Post Sat Mar 29, 2014 10:01 pm
Thanks, my first option was what I would have preferred as it could still be removed if needed, soldering the replacement to existing loom.
Just wasn't sure if they used a different plug or if I would need the whole washer pump set up.
Thanks Brian
