how long to take the motor out?
xavier
I have two weeks holidays coming up and I thought about pulling the motor out of my 323i so that I can fix a broken exhaust stud and an oil leak. Is removing the whole motor a very big job? Will the timing etc need resetting? I have a good engine crane and engine stand. I have only taken motors out of aircooled VW beetles in the past and that is a totally different cup of tea. Are we talking a 5 hour job to get the motor out? I get the feeling it may be easier than removing and refitting the head.
- **BANNED**
Allow half a day.
If you lift the rear of the car,reverse it onto DiY type ramps,that helps to reduce the 'dangle angle' that you need to achieve to clear the slam panel.
I have always removed engine/box as a unit,and found it easy to seperate/re-assemble on the garage floor.
Un-plug the engine ECU and feed the plug through into the engine bay,then once the C101 plug is withdrawn you can leave the engine loom attached to the engine,saves a lot of messing about with individual connectors.
Do not forget to un-bolt the clutch slave cylinder!
Youth is wasted on the young.
