X5's
leeparkes
Post Sun Mar 23, 2014 12:11 am
Ive got a weird itch for one...:)
Looking to spend around 5K so will be an early model and im swaying towards the 4.4 V8 type.
imo 3.0 will feel slow to me and i hate diesels with a passion.
but my question is what are these like to live with? iirc they are based on an E39?
Any problems to look out for? ie 4wd system? and is the 4.4 model the pick of the bunch?
Im getting tempted by this...
http://www.ebay.co.uk/itm/2001-Y-BMW-X5 ... 461c892972
Thanks (in advance)
leeparkes
Post Sun Mar 23, 2014 12:38 am
Just curious, did they ever do a manual X5?
Post Sun Mar 23, 2014 1:31 am
Not seen a manual ? If you must own one then get a 4.4 or a later 4.6 not the 4.0, they are really thirsty... 8O
Mine is a 2003 4.4 with LPG it's a good car, although I never go long distance in it I'm scared of something falling off :o:
Kos
Post Sun Mar 23, 2014 2:12 am
They did both the 3.0 petrol and diesel with a manual box, but i would say stick with an auto and either a 3.0d or 4.4 v8
We've had our 3.0d for 18 months and all it's needed is a starter motor. If you can find a v8 on log it will make sense as there's less to go wrong
Dervs have 2 things that wory me, a turbo and the fuel pump and both are expensive. Thankfully they don't have swirl flaps
maxfield
Post Sun Mar 23, 2014 9:50 am
I drove and worked on a fair few when I was working somewhere a few years ago. There was a fair few X5s that came in. I think autoboxes suit them more than manuals.
Apart from regular maintaince the only thing I can remember changing was a throttle pedal and a couple of abs pumps.
Although they are a bit older now...
Andyboy
Alpina Colada
Post Sun Mar 23, 2014 10:10 am
Common issues are door handles, electric window switch packs, gearboxes diffs and transfer boxes and rear airbags / pumps. 3.0d's are the worst of the bunch by a long way. V8's were 4.4 or the Alpina type 4.6 which is to be avoided, loads of engine grief. Loads of horrible badly maintained ones about with horrible owners, not my cup of tea!
Post Sun Mar 23, 2014 10:22 am
I've only ever seen on manual (a 3ltr petrol) and I've worked on and driven more X5's than I care to remember.
Do not discount the 3.0 petrol!!! They are the most reliable by a long way and also not slow at all! They are geared to give decent acceleration so do not feel sluggish at all!
Drive one and see!
In general most E53's are tyred old scrap but there are some decent bargaines to be had.
They are like a big E39 touring are harder on suspension bushes, the bigger tyres are more expensive.
Watch for judder when braking, brake reaction bushes and warped disc are common.
Avoid the panoramic sunroof, they just f uck up. Check the boot well for water ingress, the battery, radio (if it has Nav) and compressor are there and it lowest point so water can f uck them.
Check everything electrical! Electric folding mirrors, central locking can fail.
Outer door handle mechs, normally on the drivers side, rear window regs, heater blower resistor can drain the battery, check for erratic fan speed.
Rear axle bushes, front brake reaction bushes, rear air springs and if it has double air suspension (normally on 4.6 and 4.8) front springs!
Diesels are the usual M57 dramas like turbos, injectors, glow plug relays, oil leaks and the auto box's on the diesels are the most common to fail.
3.0 is an M54 so pretty reliable other than the odd sensor or oil leak.
The 4.4 and 4.6 V8's are an M62 so head gaskets, oil leaks, water cooled alternators and stretched timing chains.
The 4.8 is an N62 and a better overal V8 but again expensive water cooled alternator and some (cant remember which years) suffered with worn intermediate levers for the valve tronic (think N42!!) which is a pain to put right.
Seriously, if I were in the market for an E53, money no object would be as late as possible 4.8iS as they are quick, make a great noise and are normally fully loaded!
Being sensible it would be a 3.0 petrol for maximum reliability and repair costs.
They are not sluggish and not that bad on fuel, think low 20's which is what my mrs gets in my E46 330i auto touring.
Post Sun Mar 23, 2014 10:28 am
I would rather have a w4nk with a cheese grater, again :)
Post Sun Mar 23, 2014 10:57 am
Mate of mine has a 3.0 on LPG for towing purposes, he does the same MPG as I did in my old E34 525 on gas so considering the weight/tyres etc its very good. Plenty of miles on it already but as Barry stated the 6's are reliable and easy/cheap to repair
leeparkes
Post Sun Mar 23, 2014 11:29 am
Thanks lads, much appreciated 8)
Post Sun Mar 23, 2014 11:55 am
I saw a Y reg 4.4 with 17's yesterday. Much cheaper tyres.
