Window fuse
j4gz
Post Sat Mar 22, 2014 4:35 pm
Just replaced my window isolator switch and the 30a fuse is popping what could be the issue ?
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Mar 22, 2014 7:36 pm
Do you mean Fuse 17 or Fuse 28? There are two that control the windows.
j4gz
Post Sun Mar 23, 2014 2:37 pm
Sorry it the one nearest the front not to sure on the number .
Post Sun Mar 23, 2014 6:57 pm
Numbers are on the lid.
j4gz
Post Wed Mar 26, 2014 7:39 am
Ok I started to go over the window issue forgot it check the fuse number again but when I open the passenger door all the window buttons light up and work is this normal ? But the 30a fuse is still blown as I didn't change it yet .
Grrrmachine
Post Wed Mar 26, 2014 8:25 am
As I said, there are two that control the windows; one with door open, one with door closed/ignition on. If they work when the door's open, then it's Fuse 17 that's blown:
http://www.e30zone.net/e30zonewiki/index.php/Fuse_Box
A common cause for this is that the green/black wire on the starter motor has corroded. Try undoing it on the starter and cleaning up the terminal.
Were they working before you replaced the isolator switch?
