I've come to make my wiring harness today and noticed a few pins missing on the C101 plug to what the loom table says to wire up.
8 yellow/white pin 11 blue plug inst cluster- fuel rate input
9 black pin 7 blue plug inst cluster- engine speed input
10 purple/green pin 20 check panel- dynamic oil level
14 blue/yellow pin 10 white plug inst cluster- speed signal out
15 black/green pin 1 blue plug inst cluster- from unloader relay
Are these anything to worry about? I assume they aren't and will just relate to check panel and instrument cluster?
Wiring question
e30rapidic
are you looking at an 88+ wiring diagram? they are different that the <87
e30rapidic
I did my own wiring when I put the S50 in to my '87. Still got the diagrams somewhere in excel, let me know if you need a hand and I'll look for them.
