engine and rear differenial
console
Post Thu Mar 13, 2014 11:32 pm
Hi, so today I viewed a 318is and found this
http://imgur.com/wCpiKnq
http://imgur.com/8VvCH6E
all comments are welcome and appreciated.
broadie
Post Fri Mar 14, 2014 1:27 am
Quite common for an M42 engine as the block is from a modded M40 rubber band engine.
4.1small case diff 50-100 quid . Or you could change the seal but wouldn't bother if its whining.
TPS
Post Sat Mar 15, 2014 5:34 pm
Timing Case gasket has gone, common problem, not too much hassle to fix.
