Post
Thu Mar 13, 2014 1:22 am
Yeah as Dan said, I don't think a hammer will really help at all. It wont have enough even pressure. Normally just bounces and doesn't move.
The list he gives is accurate, the socket is a very big one. would be the same diameter, near as dammit, as the top of the bush. You may need to measure the collar of the bush holder to get the right size socket to fit.
Basically you build your own bush pressing tool without the expense of getting the actual kit.
Simply place socket on the top so it sits astride the metal, drop the long threaded bolt through, attach the large washers and then the nut.
Tighten slowly and it should push it through to the correct place.
'88 325i M20, could've done with a sunroof.
