http://www.munichlegends.co.uk/componen ... ew,detail/
It's just had a boot floor repair using the best method of a reddish reinforcement kit and BMW foam.
E46 M3 track prepped high spec.
rix313
Adverts like that saying its fully race ready grind my gears. It doesn't even have a roll cage.
75 track miles, half a day?
HairyScreech
With you on that, its miles off a log book. Your talking 3k at least to get it passed.rix313 wrote:Adverts like that saying its fully race ready grind my gears. It doesn't even have a roll cage.
Is that an open airbox as well?
No its not an open air box. Its a Geoff steel racing CSL style air box which contains a BMC panel filter just like a genuine CSL one.
Andyboy
- Alpina Colada
To properly repair the boot floor, you have to go inside the boot and cut open the top skin. This is to get access to where the big lump (that the retaining bolt screws into) is welded to the skin below - that's the bit that breaks off first - the cracks in the lower section are the result of this. Unless you re-attach the big threaded bit, it's not a proper job.
That guy who posted on a forum about how he dropped the axle on that 328Ci seemed to do a decent job.
That's exactly how you carry out the repair using the reddish plates and the turner Motorsport plates.
Winx and I have done two E46's for mates of mine using the turner plates.
