torque rear
beasteybeast
Post Sat Feb 22, 2014 11:40 am
hi. about to rebuild the rear end of my e30 having removed everything and painted and replaced all parts i could. how important is it to torque every nut and bolt i put back on the car? is it necessary? and where would i find the figures?
any help much appreciated as iv never done this before and want t make a good job
gooner1
Out humping Reindeer
Post Sat Feb 22, 2014 11:51 am
http://www.e30zone.net/modules.php?name ... c&t=134960
Should be in there somewhere, beastey.
beasteybeast
Post Sat Feb 22, 2014 12:10 pm
cheers 8)
**BANNED**
Post Sat Feb 22, 2014 12:17 pm
Try and remember to check the diff/axle carrier mounting bolts every 6 months or so,there are now a number of recorded cases of these bolts working loose in use.
At a guess,the entire rear suspension assembly would have been assembled off the car in the factory,but this is very difficult to arrange DiY,my prefered method,for example,is to mount the axle carrier,then the diff,then the trailing arms.This means that it is impossible to use a torque wrench to tighten the diff retaining bolts as only a slim ring spanner will access the upper pair.
Youth is wasted on the young.
