Are the wires and stuff the same?
stevetigger
If you put the later M50 2.5 into an E30 with the M20, would there be much difference in the wiring?? Or do you have to change it all over including the drive shafts and stuff?
Andy335Touring
stevetigger
Looks just has hard as the 3.5 conversion! I will stick to the 2.7 I think
Actual wiring for an M50 c0nversion is easy enough, as the M50 goes in with it's own self contained engine loom (which doesn't even have to be removed from the engine). The only work required is cutting off of the E34/E36 equivalent of the C101 plug and replacing it with the plug from an E30.
The only problem is that the wiring is not quite long enough for the ECU to be mounted inside the car, like on an E30, so it needs to be extended or a waterproof enclosure made for it in the engine compartment.
stevetigger
But what about the propshafts and stuff??Brianmoooore wrote:Actual wiring for an M50 c0nversion is easy enough, as the M50 goes in with it's own self contained engine loom (which doesn't even have to be removed from the engine). The only work required is cutting off of the E34/E36 equivalent of the C101 plug and replacing it with the plug from an E30.
r_9ore
what is the benefit of the m50 engine over the m20?
stevetigger
Mines a M40, but the benefits are there 24vr_9ore wrote:what is the benefit of the m50 engine over the m20?
Dan318-is
its a more modern engine. it will need less maintenance generally. it has more power from standard 6 cylinders, is more responsive due to the 24v, has lighter internals such as conrods, is probably more economical, it is chain driven, has a more modern, distributerless ignition system and also has less severe cylinder head cracking problems (Allegedly)r_9ore wrote:what is the benefit of the m50 engine over the m20?
can suffer from nikasil issues tho!
stevetigger
Not an early 325i outta the e36318-is wrote:can suffer from nikasil issues tho!
Dan318-is
i suppose
most nikasil issues were dealt with anyway iirc werent they?
eg replacement engines were installed under warranty?
so a m50 that still has nikasil lining would actually be a rare find? apparently if you do find one you can just whack in a new set of rings an they are ok?? only what i have read mind
Not as easy as that would need liners if there was a problem
Here ya go
http://web.archive.org/web/200410091927 ... ikasil.htm
Here ya go
Dan318-is
so it was only m52's and not m50's
stevetigger
Looks like the M50 was NOT affected, thought as much in the back of my mind!
Propshaft from E30 325 manual fits, and you need diff of around 2.9 - 3.4 :1 for use with the E36 gearbox.stevetigger wrote: But what about the propshafts and stuff??
Dan318-is
is that cos 5th is 1:1 instead of fourth?Brianmoooore wrote:Propshaft from E30 325 manual fits, and you need diff of around 2.9 - 3.4 :1 for use with the E36 gearbox.stevetigger wrote: But what about the propshafts and stuff??
That's the reason. Otherwise you've got a useless 1st gear and no 5th.318-is wrote:is that cos 5th is 1:1 instead of fourth?Brianmoooore wrote:Propshaft from E30 325 manual fits, and you need diff of around 2.9 - 3.4 :1 for use with the E36 gearbox.stevetigger wrote: But what about the propshafts and stuff??
Dan318-is
chrikey, interesting!!
so whats the point in six gears on the m3 models?
r_9ore
ah right, they are the e36 325i's...what power we talking standard? 180-185bhp?
Dan318-is
192 mate i think
stevetigger
So technically, I could put an m50 in my car with no problems other than change the diff??
stevetigger
So you have to change the brake servo, I will stick to the M20 lump me thinks and make an awesome 2.7
Dan318-is
gearbox too steve
stevetigger
True, to many hidden costs! Will just be easy to slap a 2.5 in my cab! I wish I had that mtec2 kit on it now though!318-is wrote:gearbox too steve
Dan318-is
any engine swap/rebuild involving an m20 has to be 2.7 route imo
stevetigger
Quite right, I would make it a 2.7 before dropping it in!318-is wrote:any engine swap/rebuild involving an m20 has to be 2.7 route imo
