M52 Wiring Question - ABS in Pin 20.
mattmk1
Post Sat Feb 01, 2014 2:44 pm
Hi guys, just looking for confirmation....
My E30 vehicle loom has the red/yellow ABS wire in c101 pin 20.
My C101 plug on the engine side was taken from a different car so just has a small diameter plain brown cable in pin 20.
My M52 wire harness, as far as im aware, has no where for my ABS wire to go..
Can i just take the yellow/red ABS wire on the vehicle side of the C101 and link it to my thick green ignition wire from pin 7?
Is there a better way to do it? Any safety issues?
Post Sat Feb 01, 2014 9:13 pm
Connect a wire of similar thickness to the existing red/yellow wire from either pin 87 or 87b of the M52's DME relay to pin 20.
mattmk1
Post Sat Feb 15, 2014 4:03 pm
Thanks Brian!
Just got around to doing this today :)
