Caliper rebuild
Jamie8GTi
Post Thu Jan 30, 2014 7:37 pm
Okay So I've stripped down my 2.5 callipers painted them and am now putting new seals and dust boots on them..
Is there any secret to fitting the dust boot? its easy to pop into the ridge on the piston but feeding the outer edge into the gap between the calliper and piston is tedious as hell!! I'm tackling it with a small flat head but is there a better way?
yours sincerely.. a very frustrated zoner :x
capnmchl
Post Fri Jan 31, 2014 10:38 am
Put the boot on before you put the piston in, and then get an assistant to spread to the boot while you slot the piston in
Jamie8GTi
Post Sat Feb 01, 2014 3:29 pm
I'll give that a go!!! thank you :)
