Central locking problem
sweep
Post Tue Jan 28, 2014 6:07 pm
i have a a car in for a central locking problem, so i un-stitched the alarm as it was tapped in too the two wires in the central locking loom going down by the passengers from speaker, so then all wiring soldered back up correctly.
nothing happens via the drivers door lock when using the key so
When i try locking the car by operating the drivers door solonoid by hand the relay clicks once when it goes down and once when pulled up
the micro switch has no effect ,but when i plug one in directly to the door (inside the door)loom and operate manualy the only solonoid that works is the fuel flap one and it goes up and down as if there's a fault in the circuit
any help would be apreciated.
Post Tue Jan 28, 2014 8:21 pm
All the lock motors are connected in parallel to the same pair of wires leaving the ECU, so if the fuel flap motor works and the others don't, then either there's a wiring fault preventing power reaching them (very unlikely for the boot motor), they are unplugged, or jammed (which usually means burnt out, in which case they won't move by hand either.)
sweep
Post Tue Jan 28, 2014 8:29 pm
They all move by hand,the petrol flap one was seized but i have replaced it,
also i have found under the glovebox a looped green wire with white plug-where does this go?
Post Tue Jan 28, 2014 8:32 pm
Brianmoooore wrote:All the lock motors are connected in parallel to the same pair of wires leaving the ECU, so if the fuel flap motor works and the others don't, then either there's a wiring fault preventing power reaching them (very unlikely for the boot motor), or they are unplugged,
sweep
Post Tue Jan 28, 2014 8:34 pm
they are not unpluged
Post Tue Jan 28, 2014 8:36 pm
Brianmoooore wrote:All the lock motors are connected in parallel to the same pair of wires leaving the ECU, so if the fuel flap motor works and the others don't, then there's a wiring fault preventing power reaching them (very unlikely for the boot motor).
sweep
Post Thu Jan 30, 2014 9:00 pm
Now sorted thanks for the help.
BenHar
Post Thu Jan 30, 2014 10:56 pm
sweep wrote:Now sorted
How?
Ben
sweep
Post Sun Feb 09, 2014 10:19 am
The micro switch arm had dislodged from the pin in the drivers door and 2 solonoids replaced.
