E30 Elephant Trunk (water drain)
Racer75
Post Sun Jan 26, 2014 5:51 pm
Does anyone know where I could find an 'elephant trunk' for my E30 as mine has completly perished and is (as I belive) letting water into the cabin.
Post Sun Jan 26, 2014 5:59 pm
They are available from the dealer, about £20 iirc. If it is missing , it will NOT be the cause of your water ingress :(
threelander
Post Sun Jan 26, 2014 6:25 pm
i have one of these in good order £10 posted
adamh325
Post Tue Jan 28, 2014 4:49 am
Are they easy to replace ?, as I am having issues with water in the drivers footwell
BHadley
Post Tue Jan 28, 2014 6:42 am
As pacer Pete says it won't be the sole cause, when I unblocked mine i refitted it with vasoline and twist it on, wont work dry. Sounds like you need to get the carpet up......
ross2009
Post Tue Jan 28, 2014 7:57 pm
mine was doing the same, kept getting water in the footwell i done everything to stop it and was still coming in
i later found out there was a rust hole behind the sound deadening behind the fuse box and was coming in down the bulkhead
Turbo M20
v8 project 6.0 twin turbo
