12mm riser rear subframe bushes.
gazwhittle
Post Sat Jan 18, 2014 11:35 am
Hi guys, the rebuild is on going with the old girl and buying most of my bits and bats so I ain't running round like mad when I need them.
I was looking at the Weld on tabs to correct camber and toe, but I think I want the 12mm riser bushes for the subframe.
I'm after either aluminium or poly with solid stiffness. Only problem I've got is I can't find anyone in the uk who sells them!
I'm ideally after non weld in type solid mounts, anyone know anywhere in the uk? Cheapest I've found is £200 from the USA that's with diff bush and r tabs
gazwhittle
Post Sun Jan 19, 2014 6:26 pm
Anyone ?
