fan switch
moggie
ive bought an e36 m3 radiator for my s50 conversion and its got a brass plug in the left hand side near the top if your looking at it from the front of the car,can a fan switch be screwed in, in place of the plug and if so does anyone have a part number for said switch
jmc330i
Yes, that's the place for the fan switch. Don't have the part number to hand, but it will be on Realoem or BMWfans.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
moggie
what model bmw car do i want the fan switch out of anyone no to fit the m3 radiator
jmc330i
I ordered mine for my S50B30, but I'm sure it's the same switch used in many BMWs.
61 31 1 378 073 - From BMWfans is the part number for the 91/99 degree double temp switch.
James
'91 325i Sport
'91 325i Sport
Depends what temp stat you are running, if your using an 80 stat and no viscous fan you will want an 80/88 fan switch, part number for that is 61 31 8 361 787
moggie
yes ive removed viscous fan so its to run electric
jmc330i
Thanks Dan, I couldn't find the 80/88 switch on BMWfans.
James
'91 325i Sport
'91 325i Sport
