Hydrocarbons
minimatan
Post Wed Jan 15, 2014 11:29 pm
Well, after a year (!) my car is on the road with new valves and a few other bits. Nothing fancy, but when your Dad's a mechanic, well, you sit at the back of the queue!
They have been adjusted and the emissions are 300 hydrocarbons, which apparently is very good.
Can someone explain to me what this means and how it translates to CO2 emissions that are now quoted with all new vehicles?
325i Sport Diamond Schwarz 1989
Post Wed Jan 15, 2014 11:49 pm
300 is actually not great . A good running 325 should have a HC reading of 150 or less and CO of 1% ish . Tight valve clearances, air leaks or a lean mixture will lead to a higher than normal HC reading.
minimatan
Post Wed Jan 15, 2014 11:51 pm
Oh. *bubble burst*
minimatan
Post Thu Jan 16, 2014 12:16 am
Hopefully it'll clean up after a bit of running and some of the fuel injector cleaner added to the fuel tank by my cunning mechanic!
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Jan 16, 2014 10:07 am
The only thing a fuel additive will clean is your wallet. Get the injectors removed and send them off to Injectortune.
Post Thu Jan 16, 2014 10:59 am
Grrrmachine wrote:The only thing a fuel additive will clean is your wallet. Get the injectors removed and send them off to Injectortune.
THIS!! The best investment, BHP/MPG for your £ you will ever make.
minimatan
Post Thu Jan 16, 2014 7:47 pm
Thanks guys, I'll get my head around the advice and where I stand in the general context of what needs doing to the car, and I'll take it from there.
A quite glance at their website makes it seem quite reasonable, so I may get it done soon, when the rear subframe mounts are being replaced.
minimatan
Post Fri Jan 24, 2014 11:08 pm
With regards to the injectors, would they be the reason that the sport is very 'jerky' at low revs in 2nd gear when keeping a steady throttle in traffic?
Post Fri Jan 24, 2014 11:33 pm
minimatan wrote:With regards to the injectors, would they be the reason that the sport is very 'jerky' at low revs in 2nd gear when keeping a steady throttle in traffic?
Very likely to be one of the factors involved.
minimatan
Post Fri Jan 24, 2014 11:35 pm
The kind of 'kangaroo' effect? Anything else that it could be?
Post Fri Jan 24, 2014 11:49 pm
Air leaks, TPS, and the effects of the uninitiated playing with every adjustment that they shouldn't be, to try and cure the kangaroo effect.
Injector refurb is the place to start.
minimatan
Post Sat Jan 25, 2014 12:17 am
Post Sat Jan 25, 2014 1:01 am
Alot of 1980s fuel injected vehicles have this 'kangarooing' effect, because they partially cut the fuel off when coasting along in traffic, so it is constantly pulsating the fuel flow.
A chip can help improve the driveability quite significantly, by eliminating the un-needed sections of the program on the standard chip. winkeye
