HI,
Ive just bought one from the states (off here) and was needing a bit of wiring advice as it`s a right bunch of b`stards where the radio fits. Any pointers will be muched looked at.
(bunch of b`stards= grouping of snakes)
Blaupunkt London sqm 37
BenHar
That doesn't really help if you just want to use the standard connections.Speedtouch wrote:http://www.e30zone.net/e30zonewiki/index.php/E30_ICE
Ben
Thanks but quite true, we need to go back to basics as in when they were made...........Maybe Brian will come along?BenHar wrote:That doesn't really help if you just want to use the standard connections.Speedtouch wrote:http://www.e30zone.net/e30zonewiki/index.php/E30_ICE
Ben
There's a wiring diagram for a 1984 model here - I take it you're fitting the HU to your 1987 316 Baur?
http://www.e30zone.net/e30zonewiki/imag ... e30_84.pdf
Yes I am and I think this could be what I`m looking for .
Thanks for that !!
Thanks for that !!
BenHar
So you need a C302 connector which should plug into V, W, X, Y, here:
http://www.e30zone.net/e30zonewiki/inde ... ory_Socket
Ben
Ben
polsta
What I did - if your radio has no connectors
Take it to a car audio shop, as I also put a new oem stereo loom in the car - I took that aswell (you could just real them the block you have ) And they made me an ISO block up for £15
