The Engine: Was originally a SuperETA prefacelift but converted to DME1.3 and originally fitted to a facelift e30
Now I've put it in a pre-facelift (which had DME 1.1)
Good battery, all connections checked and engine is well earthed
Observations:
When the key is turned on the ICV buzzes away and the check light and inspection light come on. No other indications.
The car wont start although the DME and a relay inside behind the glove box do click.
I have jumped the coil (terminal 15 from the battery - nothing)
Tried to start on the diagnosis connector jumping pins 11 and 14 - nothing
But when I put a bulb on pin 11 on the diagnosis connector it was lit and dim - there was 10v there. When we turned the key to start it went v bright.
So I checked the cab (m30 DME 1.3) and there should be zero volts at the pin 11 and 12v only when the engine is cranking
I've taken a couple of pics
I'm Mr Thicky at all this but I think I have got live voltage (but only 10v) at the starter solenoid 2.5 black/yellow when I should have zero.
Why.....god only knows !!
Any help very much appreciated
