Guys when I unlock the drivers door the doors unlock. When I try n lock it the key turns, It does click however.
I tried locking the car from the boot. But the red lights started flashing.
Any ideas!!
central locking advice/problems
So what happens if you lock it from the passenger side?
Not quite sure what you're describing, but sounds like the L shaped alloy bit on the back end of the lock barrel has worn, seized, or both.
Door card off, flip off the C clip and pull the barrel out.
ameetgill1
On the passenger side.. Again the car unlocks but the difference is the passenger door locks supposed to the drivers side.
I have to lock the drivers door from the inside.
Everything was fine had the interior changed, since then the fuse went.so I changed it but no differenc.
This makes no sense!ameetgill1 wrote: Again the car unlocks but the difference is the passenger door locks supposed to the drivers side.
